Removes the MSDP SA cache server.
vrname | Specifies the name of the virtual router on which the MSDP cache server is configured. If a virtual router name is not specified, it is extracted from the current CLI context. |
By default, the router does not send SA request messages to its MSDP peers when a new member joins a group and wants to receive multicast traffic. The new member simply waits to receive SA messages, which eventually arrive.
Use this command to remove the MSDP SA cache server you specified with the configure msdp sa-cache-server command.
The following command removes the MSDP SA cache server:
unconfigure msdp sa-cache-server
This command was first available in ExtremeXOS 12.0.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MSDP feature, see the Switch Engine v33.1.1 Licensing Guide document.
